Coolant Leak from fan temp switch?
Not Special
So, the small (very small) puddle of coolant on my garage floor clued me in to a coolant leak. Jacked up the car and took a look, it looks like there's a small ribbon of fluid coming down the back of the radiator on the driver's side, with the point of origin appearing to be the fan temp switch.
I already checked for the milkshake and don't have one, so I'm positive the leak from that area is the problem, not headgasket or oil cooler seals. Is the problem some sort of o-ring/seal for that switch that needs replacing. Since I'd have to take the switch out to do that, should I just replace the switch too (since with a seal it's something like $15)?
What the devil do I use to get the switch out (besides a German midget)? And, finally...do I have to drain the coolant in order to switch out the switch?
The switch has a small gasket that is probably leaking. A new switch is about 30 bucks and comes with the gasket. Since you are pulling it to replace the gasket, no point putting back in an old switch.
the switch has a seal ring similar to the oil plug seal ring, which probably contracts when the weather gets cold. I think you'll need to remove the radiator to get to the switch.
Not Special
Not Special
