M030 strut variants
The only part number I can really figure out is 951.343.032.32 for the M030 adjustable ride height struts. This will fit up to a late 944, the S2, and the 951 apparently? There was a similar part for the 924/924s, early 944, and the 968 as well if I'm not mistaken. The part #s would be nice but really I just want to know which ones will fit where...I would really like to have this option package conversion for my 89 8v NA. The strut housing is all I am concerned with- the insert and upper mount make no difference.
The reality is that you can get the Adjustable ride height kit with Koni Inserts from Paragon and you've got the adjustability and the koni without the hassle of finding the M030 struts. The only reason you'd need the actual M030 with the factory springs/collars is if you needed them to stay in class for racing.
Steve
Steve
You are exactly right!
Guess what?
I need them to stay in ES for autox.
The real pickle is do I hope no one notices KLA monoballs or do I fork out $377 apiece for stock upper strut mounts...
Guess what?
They are adjustable, you just have to remove them to adjust. Just a thought, in SCCA stock class shock absorbers are free which means that you dont need to use the OEM housings as long as the mounting points dont change. So in theory you could take another strut housing and convert it to take koni yellows and cut off the spring perch to accept the adjustable spring perches.
hmmm that is a thought-- I had already taken advantage of that clause by modifying my housings to accept koni sports...but modifying them for adjustable ride height doesn't seem like it would fly- I thought the rules said that dampners could be changed, but I don't think it means other parts of the strut?
And I don't have any way of putting threads on a non-threaded perch.
According to the letter of the law that should be legal.
Now, the only question is: are the bodies of the M030 shocks on 87-89 944s threaded or do they use a threaded collar that goes over the strut housing similar to a Ground Control setup? I know the early M030 cars used threaded collars.
oh boy the rabbit hole goes deep...
J, I agreed with you, especially if the threads are on the shock and not the strut housing. I attached a diagram of struts for late cars. Now the question is are the threads on the strut housing or on the shock?
I already have new koni sports; I'd like if I could put them in some threaded strut housings. Someone with a 924 m030 setup is sending me a picture sometime soon.
I can tell you without a doubt that the 924 M030 uses a threaded collar. Thats what I had until I replaced it with Ground Control. Here is a pic of 968 M030 struts that are for sale on Ebay, and they use a collar, so I am going to go out on a limb and say that the 87-89 944s probably use collars as well.
So could I put those collars on my current struts, get some late 944 m030 springs, and call it a m030 package swap? How is the collar secured to the rest of the strut?
Would I maybe be able to get away with running those 968 struts...?
The weight of the car holds the collar on the strut. It just sort of slides over the housing. I would try to see if you can find a blown strut, and cut the spring perch off to do some test fitting before you hack up your strut housings. Im not sure the the diameter of the regular strut housings is the same as M030.
To answer your question, yes you can do that assuming the collar fits. I dont know if the 968 struts would work.
