Gas smell inside cabin
Canadian Yankee
When ever I shut my car off and leave it sit for a little bit there is a strong odor of gas inside the car. I just replaced the Carbon Canistor as there was a Porsche service bullitin on it and my car had the simptoms. But I still have a gaas smell inside the car. What could be causing this?
On my old early 85, the hose connecting the filler to the tank was loose. It caused a strong gas smell. Just remove the carpet on the right side of the hatch, and check the clamps. I tried lots of things before finally getting it.
On my early car there is a hose attached to a spigot under the filler neck. It came off and if the gas jockey was careless, gas spilt in the filler neck area dropped into the cubby. Took a while to figure this out, re-attached hose so spilt gas ran down hose onto the ground, hope it helps,
Mike
Mike
i have this problem also on my 924S
would be cool to have a checklist for this problem
i can follow a thread but would prefer working from a checklist.
is the gas smell an indicator of fire risk?
It helps if you make an adapter to go over the filler neck and pressurize the tank to about 5 psi and listen for leaks. If there is a leak that will deffinetly help you to find it.
P.S. One guy brought a car in that the previous owner put an aftermarket amp in trunk. He secured the amp with 3 inch long wood screws. Guess where the screws went.....oops!
mine ended up being broken brittle hose, busted by careless smash repairer
every left hand corner I took, strong gas smell would enter cabin, I thought at first fuel cap, but there was no smell on the outside of car/neck
my issue is a gas smell when i fill all the way. i fill 3/4 of the way and no probs.
87 924S
