Stripped starter two sided bolt...
Lifetime Member
Lifetime Member
I went to check to see if my starter wires were tight (having a minor startup issue). The main power was indeed lose. So I tightened it. Sure enough, a few foot-pounds later, the bolt (or the nut, not sure which) stripped. It won't come off, even while pulling on the wires while I turn the nut to generate some outward force. No luck. It's an O'Reilly Auto Parts Rebuilt Bosch starter, with a lifetime warranty. Any ideas where I can get that bolt if it's indeed the bolt? While they will probably replace it under warranty, would rather just swap out the bolt.
-M
-M
Just tell Reilly it spun when taking off the nut. The Bakelite is probably cracked and it's not worth the effort w/ a Lifetime Warranty. Even though the Lifetime rebuilt might not be as good as a new one it's hard to beat the warranty. My son used to go through CV's on his Acura Legend coupe every 6 months driving pizza and they replaced at least 6 axles for free.
