Need a head (85.5)
Old 10-05-2007 | 12:23 PM
DarylJ's Avatar
DarylJ
Default Need a head (85.5)
So I finally brought my head to a machine shop (same one Holbert's uses). It took the guy about 3.5 seconds to see what was wrong - I have a crack between the water jacket and one of the head bolts (under the cam tower). This seems like a reasonable explanation of why/how I ended up with my milkshake.
Between this (which he won't repair, but might be repairable) and the bolt I broke off near the front water jacket (and proceeded to break off an ez-out in it) I think it's time to find a new one. Anyone have something that's either ready to go, or that has bent valves and is in otherwise good condition?
Old 10-05-2007 | 12:27 PM
schwank's Avatar
schwank
Herr Unmöglich
Are early and late heads any different? I have a head from my 83 parts car that has a couple bent valves but is otherwise good.
Old 10-05-2007 | 12:30 PM
Wipeout's Avatar
Wipeout
Not Special
E,
I'm pretty sure that the 8v heads 83 through 85 are the same. Thought you were keeping that head.
Old 10-05-2007 | 01:08 PM
GodSpeed's Avatar
GodSpeed
Nissan Rulez
I think theres a guy on the pelican board selling a good head for $100.
Old 10-05-2007 | 01:09 PM
StoogeMoe's Avatar
StoogeMoe
I have one from an 84, but you may not want it. It's been cleaned and everything. The machine found a problem when they removed all the valve guides. The problem is the previous owner had a belt failure which cracked the area around one of the valve guides. The head was repaired by drilling out a larger hole for the valve giude, and then a custom guide was fabricated. So you'd have fabricate a new one. Probably not worth the trouble, but keep it in mind.
Old 10-05-2007 | 01:56 PM
M758's Avatar
M758
All the heads will fit just fine. I have an late head on an early block. I could just have easily put an early head on a late block.
Quick Reply: Need a head (85.5)
