Timing Belt Idler Pulley Torque Spec
I pulled the front cover off my engine for the first time this past weekend to check for a front balance shaft seal leak and I discovered that the idler pulley had fallen off the front of the engine. While it was doing this, it pushed the balance shaft belt off its track where it lay nested at the bottom of the cover. How my timing belt was not involved, I don't know. I was going to take a pic of the carnage that I found when I opened up the cover, but my wife "hid" the cameras. I couldn't find one...The picture below explains everything.
Anyway, I have purchased new hardware, and I wanted to make sure that I fasten the bolt for the idler pulley correctly and wanted to know if anyone had the torque spec on it. Any advise would be appreciated.
Thanks,
-bp
'84 944 N/A
Thanks,
-bp
'84 944 N/A
Thanks,
-bp
'84 944 N/A
Thanks,
-bp
'84 944 N/A
I guess we live under a good star
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
It's always such a good feeling to catch these things before they wreck your life.
When I went to replace my belts I found that my balance belt idler bearing was shot and the roller was slowly melting.
I know my car more than I ever had hoped lol.
I would recommend against loctite because it will be a PITA getting off next time. Once properly torqued, it shouldn't give you any trouble.
