clutch job finish! but wont start doh!
08-05-2007 | 08:03 PM
Just finished everything.. connected the starter and tried to start the car. no good.
Car cranks but will never start. I swapped a the starter with my other 944 and still no good.... anyone know the problem?
08-05-2007 | 08:05 PM
Let me be the first to congradulate you. Did you by chance put the sensors in wrong?
the reference sensors? they can be wrong?
08-05-2007 | 08:06 PM
They say the tach will bounce while cranking the car if your reference sensors are ok. Are you seeing this?
08-05-2007 | 08:07 PM
mmm leme go check, its freezing outside and looks like its about to rain brrr.
08-05-2007 | 08:11 PM
okay tach not bouncing at all..... double checked reference sensors connections they are good. So u guys think i got the 2 sensors mixed up?
08-05-2007 | 08:14 PM
Sounds like the right path.
Did you disconnect the assembly while doing the clutch job? If so, are you sure they are in the right spots?
08-05-2007 | 08:16 PM
i just pulled both the reference sensors out before i took off the bellhousing.
08-05-2007 | 08:20 PM
with the other starter when i cranked the car i could hear a free spin or something for a second after i stop trying to crank... mmm ima go pull the reference sensors out now and swap em and see whats up.
08-05-2007 | 08:24 PM
Just swap the connecters, the reference sensors are the same part number.
08-05-2007 | 08:25 PM
oh crap thanks.. im glad i was sitting here procrastinating =) ill go swap the connectors as said.
08-05-2007 | 09:40 PM
muahahaha its alive!!! time to go play with the new clutchy =D thanks guys
08-05-2007 | 10:43 PM
Awesome, congrats! I did that too
