968 ABS and speedo fault
Hi
Porsche 968 94L convert.
Has anybody had the following problem
My ABS light is on all the time when the ignition is turned on and my speedo has stopped working . both happened at the same time don't know if it is coincidence or something else
Thanks for your help
Eli
Eli
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Start with fuses and relays...
But if the ABS light never goes out on key-on, there's even more chance it's just not getting power. A bad sensor would show up as the light clearing after bulb check, then coming back on.
