Unusual question (how to rekey fuel cap - RV)
Pelican parts knows these cars (Parts heaven too) so you may want to call either up and explain your problem. Pelican's website has alot of pics and help.
Good luck
Good luck
I'm sure your local locksmith could bang it out in a jiffy. They can also key blank tumblers for your Kragen (likely Stant) cap to match your ignition. Not to mention you'd spend a little dough at the local mom and pop.
Man... I'm gonna fear getting gas now that you brought this up. I better be gentile with mine!
What I did is bought a new cap and it came without the cylinder. So I cut the old cap with a saw, at the lock cylinder, removed the cylinder, inserted the old cylinder into the new cap. It snapped right in to place and I was good to go.
