Fuel Line Replacement
I will be replacing my fuel lines on my 86 na soon. I want to use the compression fitting on the fuel feed steel tube end so I can use Aeroquip hose (FC332-6) with AN fitting (-6AN female). It appears from past postings that the fuel feed line (steel tube) is metric..10mm OD (.3936"). I've seen Summit Racing offers several makes of compression fittings (AN to Tube) in aluminum from Earl's and Russell. The size of this compression fitting is -6AN male to 3/8"OD tube. 3/8" OD tube is .375" as compared to the 10mm OD tube of .3936". Was wandering if anyone used Earls or Russell's compression fitting for 3/8"OD tube. Summits part # for the Earl fitting is EAR-165006ERL. I beleive as the nut is tighten, the compression sleeve was seal onto the tube and fitting housing. I saw Lindsey Racing's and Pauer compression fittings (both metric size). They seem to cost lots more than what Summit offers. Just not sure if there would be sealing issues with the 3/8"OD fitting on 10mm OD tubing. Any experience out there???
The Lindsey fuel line kit looks to be the safer kit to install($140). I'm using he SFR kit($89). The SFR kit is kind of scary to have clamps over your headers. At the minumum, get the lindsey kit that bites in under the pass wheel well lines or replace with factory fuel line upgrade where the crimps are replaced with heavier threaded fittings(expensive $400). I think that is 3 or 4 pieces OEM but it does get messy on install.
-Dave
'86 951
-Dave
'86 951
Dude, save yourself the drama and questions and just buy the correct hardware for it.
Line to Fuel Pressure Regulator
JM 0608TL 8mm hard line fitting to -6AN fitting www.europowerinc.com www.motionindustries.com $8.91
4051 Compression nut for 8mm hard line www.europowerinc.com www.motionindustries.com $0.81
10054 Bite ring for 8mm compression nut www.europowerinc.com www.motionindustries.com $0.57
FS-6 AN -6 Fitting www.batinc.net www.batinc.net $5.50
Line from Fuel Pressure Dampner
JM 0610-TL 10mm hard line fitting to -6AN fitting www.europowerinc.com www.motionindustries.com $9.22
4101 Compression nut for 10 mm hard line www.europowerinc.com www.motionindustries.com $0.90
10104 Bite ring for 10mm compression nut www.europowerinc.com www.motionindustries.com $0.69
FS-1606 16 x 1.5 Metric to -6 AN fitting for Fuel Pressure Dampner www.batinc.net www.batinc.net $18.30
4" Braided -6 AN Hose Jegs, Summit Racing $20
+1 on the Lindsey stainless braided lines. I would have used the Rennbay lines but didn't like the blue ( sorry Travis ) yes, you have to cut the hard fuel line in the passenger front wheel well. They give you all the stuff you need, including a small tubing cutter. I also put in their adjustable fuel pressure regulator and gauge.
