steering rack question
It should be the same on '86. If you want a cheap set of brand new tie rod ends let me know, I just completed the entire rack job 2 weeks ago and have extra parts. While your in there, check the rack to cooler line, there is usually wear on the hose near the motor mount/knuckle, it bends on an 80 degree angle and takes heat/wear.
Replace the allen head bolts on the knuckle with the rennbay kit, trust me, the allen bolts strip, the rennbay kit converts to 19mm.
-Dave
'86 951
-Dave
'86 951
