MAF power wire - is direct connection to battery bad?
I spent a good 30min doing a beautiful job routing the power wire for my maf along the stock wiring harness, sticking in a stealthy fuse, connecting it up to the battery terminal, heatshrinking all the connections, etc. I then looked at the wiring diagram again and see that it says to connect it to a 12v that turns on/off with the car.
Will having the maf power connected directly to the battery cause it to drain the battery while the car isn't running, or can I leave the power wire connected up on the terminal?
What is the best wire to use for the 12v on/off power for the maf?
