Engine Rebuild Roadblock
Ok I am having some trouble removing the connecting rod caps so I can view if there is any damage to the crank at each spot. Odds are I will be taking the whole crank out, but for now I need to do this so I can pull the pistons/rods out and check everything out to see if I should be looking for a new block. So yeah I got all the nuts off, but the caps refuse to move. Any tips on freeing them up? I don't want to damage them and I am being VERY careful with this rebuild.
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Strange. Mine took a little bit of manpower and pulled free. I suppose you could get a small piece of wood and place it on the rod cap and hammer it firmly, but not to slam the hammer onto the cap so hard you damage it. This could wake them up a little more and make it easier to remove.
Hey Man
Originally Posted by special tool
Take your small plastic mallet in your right hand and the rod cap in your left.
Tap on one rod bolt as you pull upward on the rod cap.
