head gasket prep?
You are on the right track, tap the heads of the alllen head bolts holding the water passage on the cylinder head down with a hammer to help free them up. They may be seized up and can be a bear to remove.
A good 6pt deep socket will be necesary to remove the cylinder head bolts.. i cant remember the size but i am thinking 19mm maybe ? 12pt will probably slip on the nut head, it did with my car.
Also when removing the cam tower, remove the bolts in sequence and also tap the head with a hammer. If you do not remove in sequence, you greatley increase your chance of having the bolts getting hung up. You will also need a fairly long 6mm (i think thats the size..) allen key, preferably socket.
