[944S] power steering - exp. some kind of problem
8th Gear
hi all,
My Power steering was leacking so I decided to rebuild it.
The hole thing is now dismounted except the thing in red on the image below. Any clue how to get it undone ?
Thanks very much for the help
There should be flat sides on the red piece. Use a wrench that fits the flats and unscrew it from the rack. Since you already have the rack out of the car you will probably need to put it in a vise so you can get enough pressure to unscrew the red piece. By the way when I did this on several racks I used a large pipe wrench to unscrew this part but it does leave a few marks on that part. The marks dont hurt anything but using the proper wrench is the best way to go.
