Early offset wheel on 87+ 944. Why Not?
Old 06-25-2007 | 03:07 PM
M758's Avatar
M758
Originally Posted by JayP
Why not? Is it clearance of the fenders or is a wheel bearing issue?
Fender clearance.
However you can just fit 23.3 mm offets 15x7 wheels using 225/50 R15 tires on a 87 or 88 944. If you have enough negative they will just fit in fenders.
I know this because years ago we had a 944 spec car running like this. Soon after we changed out rules since it provided a track advantage that only the 87 or 88 cars could match. Now we all run stock track width.
Old 06-25-2007 | 04:30 PM
JayP's Avatar
JayP
Thanks Joe- If it were a bearing problem, I'd give up on these. Looks like I'll get the bat out.
I used to have a Subaru that used a weird offset and any other offset meant new wheel bearing every 7k miles.
Quick Reply: Early offset wheel on 87+ 944. Why Not?
