Fan amperage draw
What's the amperage draw on the 3 blade cooling fans vs the 6 blade? I'm about to do the upgrade and I am debating on adding relays to control the the fans or just running the stock wiring.
Stock wiring works fine. I never had any issues with the '84 after converting. The plugs work, although there's a 90 degree difference. I believe the motors are pretty much the same. The flow from the 6 blade fans is much better though, as well as quieter.
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
when i did the swap from 3 to 6bl/shroud on the '84na, i had one connector backwards and the fan was turning backwards.
put a piece of paper on the front of the radiator when the fans are on to make sure they're pulling air thru the rad.
87951
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
87951
