Front wheel bearing inner seal
Clarks-garage is not working at the moment and I'm stuck. I can't get the inner seal to come off. The shop manual says use a screwdriver and pull off but it wont budge.
A big honkin standard screwdriver, just slip the end under the lip and use the opposite side lip area as a fulcrum - it will probably destroy the seal but it will pop out and leave nice greasy "O" on the wall...Bruce
Hey Man
I drill a very small hole in the case, screw in a drywall screw a few turns and yank it out with vise-grips. I can't recall if the inner seal has a hard case facing out or not but it works good on the rear main seal.
