Strut/shock upgrade question
spring rate and comfort have alot to do with shock travel too
a 50lb spring rate car slammed on to the bumpstops will feel like ****
i'm currently running a 500lb spring at the front on my daily driver, but with 2.5" of shock travel before i even get to to the comrpesable bumpstops, the car is pretty damn comfortable.
Originally Posted by HIGHBOOST
That's def. a good point what shocks are you using Fork?
the porsche currently lacks a suspension all together...
Thanks for the info. So how well do the 220s perform? I'm not sure I want to go to a rate where I have to change the bars, but whatever it wouldn't cost that much more. Ultimately it might be up to my mechanic (who had an '84 944 track car before) because I'm feeling rather lazy after the whole painting project, which should be done within a week.
I think I read 5 or 6 lbs. Nothing huge, but that is unsprung weight so the lighter the better. I was going to get the solid bars until my friend found a set of bars in the back of his warehouse. They have since been discontinues by sway away so he gave me a deal.
Originally Posted by J Silverman
The rear is much more expensive to upgrade. I got lucky and got a set of new 30mm hollow torsion bars for $250 which i the price for solid bars. Out of curiosity Ive called around and most shops want 7-10 hours of labor to replace the torsion bars. Then you need to consider replacing rear bushings while you are in there which will add a couple of hours of labor. Then you have the alignment which is 2 hours easily if its a 4 wheel alignment. This is why Ive decided to attempt to DIY. Then while Ive got the car off the ground Im going to swap a manual steering rack inand repalce the front suspension too. SHould be an interesting summer!
A few tips:
- Do the bushings! They're easy (maybe 1hr total), and are a nice distraction midway through. Plus...you won't want to do this job twice.
- Use the "spreadsheet" method for indexing the bars. Got mine spot-on in the first attempt.
- Use lots & lots of fire to remove the torsion bar bushings. It's fun & easy. Done right, they should just slip off without much effort.
- Get help! Not so much for technical advice (it's actually a fundamentally simple job), but for muscle. The rear end is heavy, and hard to put in by yourself.
Originally Posted by tk's944
so is it worth the $100 for the hollow tubes
I just did this job, and let me warn you...it's not very fun. It wouldn't have been so bad, if it weren't for 3 broken bolts (each one taking anywhere from one evening to almost a full weekend to 'fix').
