Was a 21 gallon tank really necessary?
Originally Posted by KY944S
I'm waiting for a MPG chip for my S or N/A. I'm starting to steal my wifes Carolla any chance I get
Can the 944 be ran on ethanol (E85)??
You could probably do it with only a custom chip from someone, but then it would be E85 and nothing but. A standalone with a Flex Fuel sensor would let you run any combination of E85 and gas that you want to.
Re: ethanol ... Check your manual if you have one. I don't have mine in front of me but I'm pretty sure it says E85 is just fine with no mods necessary ('87 944). In fact ethanol is often blended in with regular gas anyway.
You don't get much gain, though, since I believe ethanol gets worse mileage.
I paid $3.29 for 93 yesterday
but my tank is nowhere near 20 gallons - I put in more like 12 gallons and it looks like my gas guage is almost full*
*disclaimer: I think I've got a ground loose back there as my tach has been acting funny ever since I got it reinstalled with the rest of my interior
Originally Posted by porcho heat
I think the manual in my '83 says up to 10 percent ethanol is fine, but to only use it when necessary.
Too bad Sunoco Ultra 94 is 10% ethanol.
Vehicles running on E85 use 30% more E85 than gasoline. E85s octane is between 102-108 octane. If you planned to run on only E85 you could order custom pistons that give you 12:1 or higher compression (remember that higher compression actually results in better mileage), use an MSD Ignition (a stock ignition won't like that much static compression) and do a custom tune, you'd have about 10-15% more power and use only a tiny bit more E85 than before you modified the engine from its gasoline state.
Originally Posted by Andial951
so you paid about $3.42 for 93?? Your luckier than you know............
Originally Posted by Ninefofo
3.59 for premium at Arco in Santa Monica.
Move to Seattle, then bend over and enjoy this kind of rape.
Now you know the meaning of my avatar. This was taken 20 mintes ago, a coupel miles form my home. And I KNOW it's been higher, I jnust didn't have my camera then.
Herr Unmöglich
Yup. $3.79 for 92 octane in Portland currently. And my Audi gulps the stuff. I've actually been driving the track car more as it gets double the gas mileage!
