klunk/bang noise from the front suspension
1 Post
I sometimes get a rather loud bang from the suspension, especially when straightening after a turn at low speed. Also when I lift the car asymmetrically, e.g. the front left, it makes this "bang".
Last time I checked, I couldn't find any play in the suspension.
I wonder if it's possible that the strut nut that holds the shock insert got loose, and the bottom of the shock insert swings inside the strut housing?
comments?
thanks.
comments?
thanks.
If it's not ball joints or the top strut nut, make sure the large "nut" that holds the strut cartridge is tight. Mine came loose. I would have never figured it out unless I had a friend also take a peek at that. Everything else was tight.
1 Post
thanks guys for the other suggestions too - I checked those before, and they felt OK. The upper strut mount makes some noise too, but I don't think it's THE noise.
Funny thing, today is warmer, and I can't hear a thing!
