Clutch price
Is this a reasonable price for a clutch kit? http://cgi.ebay.com/ebaymotors/ws/eB...0792594&rd=1,1
Anything missing that I would need?
Also what's the going price to have the flywheel resurfaced?
TIA
TIA
Hi,
Currently about to buy the parts myself for my 84. I have it totally apart at the moment.
Re-furfacing the flywheel cost me $50CDN, check locall y for either a clutch specialist or engine re-build specialist. Tell them it is a "step" type flywheel. There are actually two surfaces that get machined, it is importtant to keep the distance between the surfaces equal. Most good shops are familiar with this, if not, take it somewhere else.
The 3 piece kits are ~380-500, when you add the bearing, fork needle bearings, guide tube, alignment tool, new fly-wheel bolts, new pressure plate bolts, shift rod etc. It adds up. That kits in that auction has everything, including the hydraulic cylinders.
Ken
Ken
