wheel lock won't budge
How about some careful dremel work? You might be able to grind off enough to break the “grip” of the remaining portion of the lock, or, grind two opposing flats on it and use an appropriate sized open end with a cheater, if necessary. HTH some😀
Autobreza (12-24-2023)
