Question on balance shaft seals
Hey Man
I'm doing a refresh on a 951 motor at the moment. Are the caps (seals?) at the rear of each balance shaft housing supposed to be loose? I'll be resealing everything but wondered about this before I tear them down.
Addic
i was told that is because the o-ring that sits inside there is deteriorated... but if you are doing a new one, maybe it is like that regardless, i noticed mine when i noticed a bunch of JB weld on the lower shaft in that spot to "fix a leak" (i have a receipt for that one....) and i was advised just put Red RTV silicone on the top where i was also leaking, since i just put the front all back together when i noticed it.
Hey Man
Hey Man
connecting rod nuts? 13mm if memory serves correctly
Addic
if its on the connecting rod, i could have sworn i just used a 12 point socket. i dont have a different tool that it could have been. i replaced them with oem nuts from pelican when i did rod bearings
Hey Man
Originally Posted by Dmitry S.
The seals should be tight. When you put new ones in, the End Plug will not move around.
Thanks Dmitry. I'm still not sure on the con rod nuts; a 12pt 13mm is too small and a 14mm 12pt seems too loose to be used for accurate torquing. Maybe I'm just being paranoid about the fit
