Clutch release object?
Ok I’m working on the clutch and I’m at this point. "Thread the long 8 mm thread bolt into the end of the release lever pivot shaft. Remove the release lever pivot shaft by holding the 8 mm bolt with a pair of pliers and tapping the pliers with a hammer or prying with a screwdriver." The question is can someone show me a picture of what is, because the part I think it is and tried to remove wont budge under extreme force.
Hey Man
Then you obviously have the right part! They can be a turd to get out. You can also try the socket trick where you put the pulling bolt through a socket and tighten; it will pull it out or at least break the contact where it's stuck.
Just tried the socket bolt trick on it didn’t budge at all. I know I had it lined up because it left an indentation on the aluminum casting were the socket was. I noticed when I first was looking at it there was some foam around the edge of it.
Remove the starter, and then remove the pressure plate bolts one by one. Take the bell housing and pressure plate/release bearing et al off as an assembly. Be careful with the pressure plate bolts and don't strip one like I did.
Once everything is off, take a large drift punch and smack that rod out from the other side. Hone the holes that it sits in for ease of future removal. That's how I did mine...
