Vitesse Stealth Maf Opinions Please
I have a stock '86 944 turbo that I want to modifiy with a maf kit. Can I get some feedback on Vitesse stealth kit?
Mark
Mark
I put one on a few months ago and liked it pretty well. I installed it over a weekend with few problem. I had to buy a couple nuts for it and fiddle around with fitting it to keep it from rubbing, but it went in quickly. The longest part was soldering up the leads for it, which you can get around by buying an adapter from vitesse for $100.
Performance wise, the boost came on quicker but other then that it was pretty much the same from the Vitesse chip I had in there. My main reason for getting it was so I could easily upgrade the turbo later without getting another chip. My mpg also dropped a bit but that's most likely due to upgrading to larger injectors.
Hey Man
