'83 924 got turbo
Old 08-09-2007, 08:13 AM
  #31
Charlie944
Charlie944's Avatar
Awesome job! What model IHI do you have on there? I run an IHI RHB6 on my Callaway 944 and have boost by as little as 1400rpm. I run a max of 1.0bar (15psi) and perhaps up to 18psi with my newly installed water/meth injection. *pics coming* Mainly because the turbo is on the "right" side...and literally that is. Good to see a 924 getting some special treatment and exposure!
Did you have to change out all the spindles, struts, etc to get the 951 brakes to fit?
Old 08-09-2007, 08:45 AM
  #32
Raceboy
Raceboy's Avatar
I'm using IHI KHF-5 from a Hyundai Terracan 2.9 diesel. When exaust is hot, I'll get boost around 2000rpm, full boost is around 2800.
I installed 951 calipers on 944 NA hubs and fabricated adapter plates for them, so everything apart sway bars (S2) and brakes is from 944 NA.
Old 08-09-2007, 08:49 AM
  #33
Raceboy
Raceboy's Avatar
I have some udpated pics of the turbo system I changed few months ago (951 IC, oil cooler, new rad fan):
Old 08-09-2007, 11:54 AM
  #34
Shabba
Shabba's Avatar
Awesome car...simply awesome.
Old 08-09-2007, 02:53 PM
  #35
944CS
944CS's Avatar
why don't you use a recirculating valve instead of the fast and furious one?
Old 08-10-2007, 10:22 AM
  #36
Raceboy
Raceboy's Avatar
Because I had one laying around and it was new, so didn't feel like buying a second one.
I can live with it
Old 08-10-2007, 12:17 PM
  #37
special tool
special tool's Avatar
Awesome, dude!
Can you keep up with Markus?
Old 08-10-2007, 01:18 PM
  #38
Raceboy
Raceboy's Avatar
Originally Posted by special tool
Awesome, dude!
Hehee, definitely NOT with this engine, but with new engine that car should smoke Markus's Jäger if everything will be as it should. Ok, it's not nice to speculate, but we'll see.
And god knows when I complete my 931 project.....that should also be pretty fast.
Old 08-10-2007, 04:04 PM
  #39
Charlie944
Charlie944's Avatar
What are you using to monitor your airflow? I did not see any MAP sensor, or MAF? I am sure the orig K-Jetronic would be difficult to hook with your turbo being on the left side.
Old 08-10-2007, 05:09 PM
  #40
Raceboy
Raceboy's Avatar
I'm using VEMS engine management that has internal MAP sensor (400 kPa version) and vacuum line is going from the intake manifold to ECU.
Old 08-19-2007, 05:27 PM
  #41
Raceboy
Raceboy's Avatar
Decided to give the engine bay a good wash and this is how it turned out. I just hope it's stays that way for a while
Old 08-22-2007, 03:52 AM
  #42
stv951
stv951's Avatar
any performance figures ?
Power measured ?
1/4 mile or other ?
Old 08-22-2007, 05:52 AM
  #43
Raceboy
Raceboy's Avatar
Best ET so far is 13.97 s @ 163 kph. Not dynoed this car yet (a bit slipping clutch), but this trap speed combined with that weight (1150 kg) puts it to 200-210 hp range.
Old 10-29-2007, 04:17 PM
  #44
Raceboy
Raceboy's Avatar
Hi guys,
Took the car to dyno, results are pleasing to say at least Numbers are measured at the wheels, so you can add some amount to get the flywheel figures.
Here's the sheet:
Old 10-30-2007, 12:14 AM
  #45
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
Peep,
What type of dyno ? How much boost to produce those numbers. Very similar BHP to a stock 951 , with less T/Q......
238 BHP @ Flywheel
Quick Reply: '83 924 got turbo
