Cylinder bore repair
I have a short block of questionable heritage, and there is a small amount of damage to the bores. It appears that something was between the rings and cylinder walls, the scoring is noticeable with a "fingernail" but there is not a ridge at the top of the bore that I can feel. Question is, what is the best way to repair this, or should I even bother. I want to build a completely stock motor, at a minimal cost.
Nothing you can do about it short of boring it out with a special process. Last I checked it was about $1500 just for boring and then you'd need to find oversized pistons. Your best bet to a low cost build is to just run it as is or else find a better short block. I may have one shortly if you decide to go that route.
Best bet is to get another good used motor. Re-boring the high silicon content aluminum properly ain't cheap nor will the OEM oversized pistons be. Some people have installed steel sleeves and I saw a thread fairly recently about a place that does repair and some kind of special coating on the cylinders. However, none of these other options are cheap....
Here's what my cylinder's looked like before doing my rebuild.
I could catch my fingernail on some of those scratches you see. I took this block around to get several trusted opinions on it. Everybody said that it wasn't great, but just run it like that. You won't notice anything.
So I followed that advice and can say that my rebuild turned out way better than I expected. The engine pulls strong. I just crossed the 10k mile mark and have no issues with loss of oil. This engine is stronger than my 86. Sorry I don't have any HP numbers or compression numbers to share with you. I might get them soon.
__________________________________________
1986 944 NA Guards Red all original 91K mi. - minty
1983 944 NA Platinum Metallic w/LSD 10000 mi. beginning a new life
1985 944 NA Guards Red w/LSD (donor car)
1984 911 Carrera Coupe (gone, but not forgotten)
"If you're not living on the edge, you're not living."
The dry sleave runs around $1k. One good thing is you can use your original pistons. Here is another site:
http://www.944online.com/cgi-bin/ASI...block-944turbo
