fuel pump wiring
I got the car back together after replacing the clutch and it ran great for a day before dying on the road. Seems I'm blowing fuel pump fuses. Pump seems fine, but the power wire seems to be shorted to ground. My first thought was that I pinched the wire when putting the transaxle back in, but there is no outward obvious sign of damage. So my question. Is anyone familiar with the fuel pump wiring from the pump back to the fuse box? It disappears over the pump. I'd like to trace it or get access to it along the trail for testing. Does it connect or is it solid back to the fuse box? Thanks.
From digging around in my 924S, the wiring goes into the cabin above the fuel pump, runs across the back of the trunk, behind the top of the rear seat. you should be able to get to it under the carpet with the seat folded down. it then disappears again on the left side of the car. My PO had cut the wiring just before it disappeared on the left. I had a right job trying to dig it out afterwards :/
Originally Posted by SoCal Driver
Check that the power connector and wires to the O2 sensor heater is clear -- not pinched and shorted out. Fuel pump circuit provides power to it.
