Sunroof Leak! How to clean the drains?
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
Has anyone ever successfully cleaned out the small drains for the sunroof? I remember a while back good advice on not to use compressed air since it will blow the tube back into the body.
Since my sunroof seal is leaking, how do I roto-rooter this damned thing to keep it from leaking into my interior?
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Under the Radar
Check the epoxy that the factory put near each inset drain tube. I had cracking that would let water in and follow the A-pillar. I applied JB Weld around each drain.
That's not the cause, but it's just a while you're in there kind of thing.
