Dropping the Suspension - Any words of Wisdom?
Ok - I got a couple of hours Saturday and a couple today. If the spreadsheet was accurate I nailed the re-indexing. I have everything back together except reconnecting the axles and installing the catback. I was out of time and I just couldn't bring myself to drop it to the ground and see the results. I am quite confident though. I measured and remeasured. The "H" measuremet from the banana plate and the hub is almost exactly wha the spreadsheet calls for. Side to side is within a 1/4 inch.
Oh yeah. Dropped the car and it was dead on, first try! Only 1/4 inch difference from side to side. I really appreciate all the help. Skip and Joe went above and beyond answering questions. Thanks Guys
Jeff
Jeff
Jeff
Jeff
Glad to hear it all worked out. That last 1/4 inch can be adjusted via the spring plate and is best done when corner balancing.
