Another Door Loack Question
After searching the archives, I was unable to find an answer to my question. When I press the lock button inside the car, the passenger door lock does NOTHING. NO sound, no movement, nothing. My question is, when the actuator solenoid goes bad, does it go completely dead, or does it just get too weak to pull the mechanism? Is there a relay that could be bad. Bad connector somewhere? Fuse? Anyone run into this problem? Thanks
Chris
Chris
