UPDATE on GTG at my house
Looks like there will be 3 things to do. I will be doing a re-seal and belts and water pump on the 2 engines. Also, I will have a 88 engine out of the parts car that has a busted block. The insides are good. If you have ever wanted to take the head off, clutch, or rod bearings, but did not want to experment on your engine, know you can practice on this one. I need to strip it down.
Same thing goes for the tranny. The top of the cae go busted, so we will be stripping it down also.
On the busted engine, we will also take the clutch off, so you will be able to see how it is to do a clutch job.
We will start a little after 10 AM.
If you have not been to my house before, e-mail, and I will send the address so you can mapquest.
toddandcharity@bellsouth.net
Or pm here.
Hope to see you Sat. We
Or pm here.
