A "where does this go", and "what is this" question
Addic
ok, going to replace all vaccuum lines, and i found one that didnt have a connection... part connected goes to the front of the throttle body, where does the other one go?
and second, i thought the plug end was reserved for dealer or something for diagnostics, but the end in focus, where is it supposed to go? it looks broken, but i dont think its very important, since it leads to a plug that sits on the engine hoist hook dileo
since I'm still waiting on my powdercoated stuff to come back...
and i may need a new injector or two since Gordon called me and said 1 or more may not be serviceable, leaking at the top of the body...
I have some time to tie up the loose ends.
spring is just around the corner though
Thanks in advance
Thanks in advance
Herr Unmöglich
1) That vacuum line heads up to the tank ventilation controls which are located on the drivers side right in front of the fusebox in the engine bay. It attaches to the white side of the black and white vacuum switch that's mounted there.
2) Reference sensor?
Addic
ok, found the vacuum line, somehow got tangled behind a bunch of wiring against the firewall. that was easy enough.
gj schwank!
but the second isnt a reference sensor, those are both in place
gj schwank!
Herr Unmöglich
Then that probably is the diagnostic sensor... mine used to be laying out as well. There is a spot for it down on the housing near the reference sensor
