Does the stock rev limiter cut spark only or spark and fuel?
If it cuts spark only, then it really should not hurt the car to hit the rev limiter. If it cuts fuel as well, then it could create a lean condition.
How does the stock rev limiter work, and am I thinking about this correctly?
For the record, I never intentionally hit the rev limiter, but it is easy to do during races (like during the start).
I believe it cuts spark only. Fuel cut, as you said, is not a good way to do it. The massive flames you can get from open exhaust while on the limiter should indicate spark cut.
Either way, it's not a great idea to bounce a large rotating mass at 6750 RPM!
Originally Posted by TD in DC
This seems very hard to believe. Source?
HE is the source.
Most anything factual you will read about the 951 Motronic programs originates from him.
OK, I am not trying to be disrespectful, I just don't automatically assume that strangers on the Internet know what they are talking about.
Now, is it save to assume that the 944 and 951 Motronic programs operate the same way with respect to rev limiters?
Isn't it horrible to have only fuel cut? Would that be bad on the engine?
Same exact fuel cutoff for redline as during deaccel. Don't believe me, rig up a timing light inside your car and go hit the limiter.
When you cut the fuel it goes extremely lean (no fuel, > 19:1 AFR). There is nothing to burn.
Originally Posted by TT
Code in the DME.
OK, so how hard on the engine is it to hit the rev limiter. I am not talking about intentionally leaving the car bouncing off of it, but rather hitting it during starts of races, at specific corners, etc . . .
I used to hit the stock 6500 limit occasionally and found the MY88 limit of 6700 was much better.
I stand... informed!
Thinking about it twice, cutting fuel would be a sure non-fire way to stop the motor from turning. Auto-ignition could happen if fuel continued to be dumped into hot chamber and keep the thing revving.
TT - why the flames if no fuel?
Nissan Rulez
Cutting only fuel is a very dangerous way to do this. Especally on a boosted engine. It creates a very lean condition and as you all know that makes heat, detonation, melts parts togeather, burns rings and removes chunks out of the piston crowns. I would avoid the limiter!
Originally Posted by schnellfahrer
TT, what is the rev limit on the Vitesse Chip Board?
Fuel cut or spark cut?
Fuel cut is like stock.
