On my 944T 1989 the rear hatch works from the botton inside but nothing from the manual key at the hatch. Any suggestions for fix or what to check for?
Reamove the rear carpet that covers the back half. Its most likely the plastic sleeve that holds the lock rod to the latch. Either broken or fallen off
My car had the same issue, and it turned out to be the micro switch thats behind the lock. If your switch still operates the rear hatch locks, then I doubt any pieces are broken.
