Head gasket ate it over the weekend.
I had suspected my car suffered from head lift for a while now. I'd smell coolant under heavy acceleration but found no signs of coolant entering the combustion chamber. It recently started dripping oil onto the #4 header, so I thought rear cam seal or tower gasket. I got it all pulled apart and found some milkshake and seepage from the lower left corner of the head by #4. What a fun weekend!
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Luis - The Garrity block never made it in the car. It was damaged when he shipped it back to me. I'm suprised you never heard about that ordeal. I was able to source a very low mile stock block for the rebuild.
It has ARP rod bolts and Raceware hardware throughout. I'm not 100% positive I wrenched the head down enough. I did then 15ft/lbs followed by 2 90 degree turns as Raceware suggested. Anyone know a spec to torque them to, in ft/lbs?
Ivay - I've run 15psi and 18psi consistantly for about 30,000 miles. Most of it at 18psi.
Thanks for the offers of help! I don't have the head off yet, so I don't know the exact damage. If the head set shows up from Paragon by the weekend, I should be able to knock it out. Luckily my friend has opened his garage so I won't need to do it in the parking garage at my condo. That would not be fun; no power, light, or heat!
By bringing the nuts up snug (15 ft/lbs) and then turning them 180 degrees, you're applying Xmm of stretch to the studs (X=1/2 the pitch of the nuts -- which I don't remember what that is...)
High-end race shops actually use dial indicators on connecting rod bolts and head studs to measure the stretch very accurately. A torque value alone isn't good enough because of everyone's lovely friend 'friction'.
Not that I disagree that a TTA (torque to angle) is better than TTY (torque to yield), but I am not using studs that are designed to stretch. I guess this is my conflict with the method.
Going with the pack
is quite monotonous.
Perry! Holy crap!
We were talking about (ok, I was going on about) how pretty your engine was on Saturday!!
Hope it isn't bad!
If you start enlisting help - let me know! I'm usually hanging out with Josh B and Aribop on the weekends, watching them do all the hard work... lol!
Hope it isn't bad!
We had this discussion over in the Turbo/S forum. What you don't want is "creep" -- or the head studs stretching over time and relaxing their clamping force. This is why people use ARP/Raceware and other stronger head studs than stock. But, there's no getting around physics. Steel is a ductile material and does stretch -- luckily engineers have figured out the limits of materials so these properties can be used to our advantage.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Good point. The Racewares have a higher tensile limit than stock, so they shouldn't stretch to yield in the same manner, but they'll still stretch. I need to get the gasket off and read it to see why it failed then I'll assess the lifting issue, if any.
