This must be a common problem - with pictures! - success!
#31
I'll tackle it again tonight. So far I have
- started with a plastic cap (3/8 ratchet) - rachet square striped.
- steel cap with 3/8 inch rachet connector - slipped and spun around the filter
- steel oil filter band wrench - simply crushed in the side
- tapped a screw driver through perpendicular, turned and ripped the metal side
- flexible strap all the way to the base with 1/2'' rachet connection - finished crushing the can
#34
Originally Posted by 75ohm
Please mind the metal shavings!
#36
I've just punched a screwdriver through the side and used it like a handle before. The problem is tightening the filter too much. You only need a bout 3/4 turn pas hand tight
#37
Items you will need:
sliding T-handle
Put extension on t-bar, place t-bar under washers.
With wrench on square end of extension try turning filter off.
EDIT* -- I used 1/2 inch set for illustration, 1/4 inch should work just fine, see a few threads down for more suggestions.
sliding T-handle
- Sliding T-handle for sockets.
- Extension Bar for T-handle (as long as needed)
- Wrench to fit end of Extension as leverage.
- 2 long cap screws with large washers that fit in holes (not sheet metal screws.)
#39
ejsaenz
I like the idea, but don't forget I'm really tight on space. These have all given me some good ideas. Looks like everybody loves a creative challenge. I can't believe they expect me to work this afternoon when I could be home working on the car.
#40
Originally Posted by dme
ejsaenz
I forgot to mention in my post, I used 1/2 inch drive only for illustrative purposes, and that I didn't have any 1/4 inch nearby. 1/4inch should be able to work for you. Plus if you use fender washers you may be able to cup them a little to help hold the t-handle in place. You may have to use a universal joint socket (tape it up so it doesn't wobble as much) or wobble extension to help with the clearance issues. Keep adding extensions as needed for clearance!
#41
Success at last. It just took my water line tool a couple bolts and six wood braces. The bolts through the braces mounting holes were the perfect size so that when I put bolts through the mounting holes they were nearly perfectly lined up with two crosswise drain holes. The water main tool fit over the brace/bolt combo and I had plenty of room to torque away. Thanks for the ideas everybody.
