First week with my 944 an i need some DIY Tips
This is my first week with my 944 S2 and i have made a list of DIY small repairs.
How can i change the light bolb that is on the water temperature side in the dash?
Do all electrical switches and ***** have bulbs in them? (i.e. The windows switches?)
How can i change the digital clock?
How can i tight the passengers side mirror ?
Is there a way to tighten the tailgate? (i have the feeling there is a sound coming from it)
What should i do to stop the seats from sliding a bit while accelerating and brakeing? (Power Seats)
And a question to the S2 owners. Where should the water Temperature gauge stay when warm? (if i am right, there are 4 segments on the temp gauge. Bottom(white) the top (red) and two in between (white)
At my car the gauge shows just a bit higher than first white line (and this after a long time...i.e driving 15-20km)
Thanx
George
Thanx
George
Official Rennlist
Borat Impersonator
Borat Impersonator
If your seats are sliding most likely the one of the bolts holding the seat slider to the car is missing.
The seats bolt on with 4 bolts to the slider and 4 more bolts holds the slider to the car frame.
Slide the seat all the way forward, remove the 2 rear bolts, then slide it all the way forward and remove those 2 front bolts.
Then the seat should come free, you might need to disconnet a power connection.
Defending the Border
Rest In Peace
Rest In Peace
George, the beauty of this car is that she's been around for awhile and much of this has been addressed here on Renn. Do a "search" and you will find much info to answer your questions, plus, learn even more about your car.
With that having been said, welcome George!
The 'tailgate rattle' you're mentioning has a couple of possibilities. First, check the cubbies behind the rear wheels for loose stuff that might be shaking around. Also, check the spare tire, spare tire well, and the jack. If anything's loose, secure it and listen again. If that's not it, check the fitment on the hatch pins. You may need to tighten them up a bit to keep the hatch shut more securely to stop the rattle.
Hope this helps!
Welcome mate,
First the good news, you bought the second finest Car Porsche produced
Bad news, the S2 cab was the Best
have a look at my page for some info on bits and pieces and projects that I'm doing. also pop on along to NotJustPorsche, where there are a few s2 guys who can assist you along with more FAQ's on P's
pretty much everything people said below is fine
as for lights, hmm, difficult, to say, I know I kept finding things that should have worked and didnt and then worked.
are you close to a Porsche club or local chapter ? hook up with another fello p944'r and compare cars.
As long as its a late 944, they alll share the same running parts
ok heres the links
my site is:
http://playback.demon.co.uk
NotJustPorsche is:
http://groups.yahoo.com/group/notjustporsche/
ok heres the links
my site is:
NotJustPorsche is:
Thanx
George
Thanx
George
Thank you all for your help!!!
You are right, next time i will try the "search" option!!
I guess i have to lay back... and enjoy the search for this car!!
believe me i am happy with the car even if it is the second best 944, or the third or the forth!!!!
I will always have in my mind a 944Turbo as i dreamed it when i was a kid,(the fact that its the fastest 944 ever built.....that makes a big sence of its own i guess) but as an adult i think the S2 is the best "politicaly correct" to fun ratio a 944 could give!
Back to the question about the mirror.
The whole mirror is rattling from the base. There is nothing wrong with the glass part, or the folding mechanism. Its just the end that is held on the door. So i guess i need to take out the inside cover and get a way to the bolts that hold the mirror.
Thank you all for your warm welcome and your help!!!!!
Take care!
George
Take care!
George
turn your mirror in towards the car, there is an allen bolt going down from the top of the base which secures it to a piece of round stock welded to the inside of your door (well, a strap is welded holdng the stock)
Originally Posted by adrian_jaye
Welcome mate,
