Need tires for my 968, suggestions?
93 968 -
Currently have Michelin Pilot Sports. Currently running rears - 17" 255/40 and front - 17" 205/50 on stock Porsche turbo twists.
I sorta like the current tires, but I feel like they are not so good in the rain or cold and NOISY.
Anyone have any suggestions on a tire that will grip in the rain, be not so slippery in the cold and QUIET!!!
Notice I need a QUIET tire! The road idiots here in Texas have this new thing about something called "chip-n-seal". It's a cheap alternative to asphalt but it is NOISY if you're driving with low-profile tires.
I don't want to go cheap, I want quality...suggestions?
p.s. it's my daily driver...
i would change to 225/245 setup to get rid of some of that understeer. i bet it plows like a truck. my S2 did with 205/245s. I have 225/255 on my 951 and think it has a bit more understeer than desired, but that can be fixed with adjustments to my sways.
back on topic.
I have pilot sport a/s on my S2 225s all around and they seem decent in the cold. they were nice in the rain at lime rock, are not noisy, etc. i will pprobably be able to tell you how they work in the snow within the next few weeks.
back on topic.
Tom - some questions...
"plows like a truck" - please be more desriptive, no race lingo please![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
understeer is where the rear end goes out first, yes?
you're saying run 222/50 on the front and 245/40 on the rear?
That would be a slightly wider tire in the front and a slightly narrower tire in the rear, correct?
So you're saying that these tire sizes make the car handle better and be able to go around turns faster?
sorry for my "don't know the lingo" frame of mind - just never raced or tracked a car
understeer is actually the opposite: when you try to turn but physics only allows you to travel in a "straighter" direction, regardless of whether your wheel is turned fully or not.
Oversteer is when the rear end of your vehicle "drifts" around, and one must compensate by turning the wheel in the opposite direction.
BF Goodrich G Force Sports. I have 17" Boxster Sport Classics on my 968 with these tires. Not sure of the size off the top of my head. They have worked well for me on both wet and dry roads and best of all, they are quiet. I even had them on for one small snowfall before I took them off for the winter season. My 968 is my daily driver also but has not seen any track work. Not sure how the tires would perform there.
I actually know of 4 cars with these tires and we all love them.
Thanks, all,
I've heard from quite a few people very positive comments about BF Goodrich G Force Sports. Looks like I may be heading that direction.
Muchas gracias!!
Harvey
Muchas gracias!!
Harvey
My Yoko EVS 100s Z rated - have been great. 225/255 x 17s. Quiet and handle great. Lasting longer than I expected. Wearing very evenly. Manual Steering, so I have to hang onto the wheel at all times. Oversteers on hard, fast corners, but have removed the spare for reduced weight and usually keep the tank on half full or less. So there's not much weight back there to keep it grounded.
Happily Amused
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
sorry for my "don't know the lingo" frame of mind - just never raced or tracked a car![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Sassilverbullet, you already have 255/40/17's in the rear, which is a decent size. I wouldn't go any smaller than this in the rear. In the front I'd run a 225/45/17 if you have the 7" or 7.5" wide twists.
Speedbump - ROFL!!!!
I can't get off the floor... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Porschefile - you're in Austin huh? You need to come join the longhorn region for an awesome drive through the best twisties in Texas on March 11th. See our website, http://www.longhornpca.org for more info.
I went ahead and got Goodyear Eagle F1 GS-D3's all around. I found I had the wrong size tires on the front according to my owner's manual. I put 225/45 on front, 255/40 rear, 17" both ends.
Car handles x8 better at least! After about 100 miles I went through some turns that my rear end was sliding out at 30mph at over 40mp and it wasn't even starting to slide!
Yeeha! Twisties here I come!
