WTB: Wiper Delete Plug and Climate Control
Hey guys, I'm looking for a wiper delete plug as well as the climate control. If someone has a climate control that i may be able to test out/buy that would be perfect. I belive that my climate control is shot so I assume that the only way to test that is to swap in another one. The reason I belive that it is shot is because my heat takes forever to get even relatively hot. I have swapped the heater control valve but that didn't help at all. If anyone has any suggestions or someway to help it would be much appreciated. Thanks, Ben
My control head is shot as well. What I did is to plug the small vac line to the control valve. I pulled loose the line at the nearest (Y) connector so that the vac to the valve was gone. This gives me heat, I hook it back up in the summer for AC. At least untill my tech has a chance to rebuild and repair my control unit. This might be an option for you.
http://cgi.ebay.com/ebaymotors/Porsc...QQcmdZViewItem
No affiliation, but saw the wiper delete plug online.
