New fluid, brakes feel spongy.
I just replaced the fluid in my brakes because it looked like it hasn't been changed sense 87' !
And before I did this the brakes had a very stiff feel, not much travel, but once in a while it would get a little soft on me so i assumed it was the fluid. So i replaced it with some high performance DOT4 fluid. And the pedal now has a inch to inch and a half of spongy feeling before it firms up.
Is there any way to get the old feel back? The actual braking feels more solid, and stops much better. I just don't like the feel.
And no, there aren't any air bubbles, I made sure and ran plenty of fluid through just to make sure the old was all out and no chance of air bubbles.
OT: My car is the first year that had ABS as an option. How do I tell (besides slamming on the brakes) if I have ABS or not?
You should have an ABS module under your hood (it will have a bunch of hard brake lines running to it but it won't be attached to the brake booster). There is also option codes listed on a label in your rear hatch - just lift the carpet that is on snaps like you are getting to the hatch release motor and rear tail light bulbs. Look for the 3 digit code: 593. You can also look at this site at the other codes you have. http://www.cantonia.com/option_codes.html
