Tech Lesson: brake caliper comparison
Originally Posted by 944Fest (aka Dan P)
Excellent graphic, Mr T. Would it be safe to say the rear caliper on a Turbo S is the same as the right most caliper in image #1?
Considering the n/a brakes aren't "small" and the standard 951 brakes are pretty big, even by todays standards - that's pretty impressive. The brakes on 951s and such really make them stand out from other cars in this category, IMO.
Come to think of it, brakes are probably the largest drawback on my e30, but I'm getting by with race pads and blue fluid.
Unaffiliated
Originally Posted by aribop
Size wise, yes, but the piston diameters are smaller than the front calipers.
Won't work. The Kokeln hats are made specifically to be used with the 993TT two-piece rotor on the MO30 hubs/spindles to get the correct offset when using Big Blacks/Big Red calipers.
The offset is a function of the A-arms, Right? (although the spindles are different--have shock mounts angled specifically for the offset, and of course the hats are different) So the Kokeln hats should be made with an offset that's correct for a late model A-arm. What else is there besides bolt hole pattern, offset, and rotor mount configuration? Unless the actual hat diameter is different. Or the the M030 spindles require a slightly different offset in the rotor hat than a standard late-model spindle. But, if the offset is correct, the bolt holes are correct, the only thing left to solve is find a rotor that'll bolt to the hat and work with an NA late-model brake setup...
..meaning that IF I put Turbo S rears on the front of an 88 n/a with Turbo Spindles/hubs/rotors they would fit but it would take extra/excessive pedal pressure to activate them?
Originally Posted by strandolph
Why won't it work? Or, more specifically, what part won't work? At this point, I'm thinking that the "finding a rotor" part won't work.
The Kokeln hats are made to take care of that bit of difference in the offset of the MO30 hub verses the stock 951 hub. Using a regular 993TT rotor on the MO30 hubs will not center the rotor with the caliper, thus necessitating the use of the aluminum hats. Also I do not know of a two-pice rotor that is made whose diameter matches the diameter of the regular 951 rotor. Good luck in your search!
See here: https://rennlist.com/forums/showthread.php?t=257774
Steve
Unaffiliated
No. Since the piston diameters are smaller, they won't exert as much force on the rotor as if you had the front calipers there with larger piston diameters. However, the rears on the front will brake better than the regular n/a brakes. You may end up having to play with the proportioning valves to get the braking bias correctly adjusted.
Slightly confused.. You started your post with a "No", yet it seems this description would describe what I asked?
Thanks Tifo, I learned something today.
That pic really makes the 968/951 caliper look small, but in reality it is relatively large. And I agree with Serge, the brakes (at least on the 968/951) were fantastic, and still are, especially compared to other cars from the same era.
I was told the 968 uses the exact same calipers for the front and rear. I know for a fact the same pads work on front and rear.
Unaffiliated
Sorry, Dan. No is the response to the question of taking extra pedal effort. I doubt you will be able to tell the difference....unless you remove the power brake booster.
I take it you mean I'll be OK, but not up to 100% capability of that "sized" caliper?
Thanks for the clarification.
Dan, the rears have slightly different mounting holes when compared to the fronts, so they do not bolt up to the 951 spindle or the 944 spindle. The 951 rears are a direct bolt on to the 944 rear mountpoints though with the longer bolts and proper spacers/washers.
