Rear Brake Upgrade for 1985.5
Old 01-14-2007, 11:58 PM
jerhofer
jerhofer's Avatar
Default Rear Brake Upgrade for 1985.5
I am running 17" wheels and have Big Reds on the front.
What is a great bolt on rear brake upgrade for 1985.5 NA 944 to balance out the front brakes?
Old 01-15-2007, 12:32 AM
greenshoes3
greenshoes3's Avatar
probably not worth upgrading.............
Old 01-15-2007, 12:59 AM
Techno Duck
Techno Duck's Avatar
Put the rear 944 Turbo brakes to even it out. They bolt right up without modification. All you need are the calipers, different length bolts, spacer washers, spring washers, rotors and pads.
Your using big reds upfront with single piston calipers in the rear??
Old 01-15-2007, 05:46 AM
tifosiman
tifosiman's Avatar
I'd like to see pics.
Old 01-15-2007, 10:51 AM
jerhofer
jerhofer's Avatar
I have attached a photo. I bought the car with the brake setup on it. The previous owner had only upgraded the front brakes. I would assume, the 944T brakes would have to be from a 1986 to work with my hubs. Is that correct?
Old 01-15-2007, 10:57 AM
MAD MAC
MAD MAC's Avatar
You can use 86 turbo calipers only because of the offset issue. Been looking for some myself
Old 01-15-2007, 11:14 AM
jerhofer
jerhofer's Avatar
Do you know the sizes of the bolts? How do you determine how many spacer washers to use? You wouldn't happen to have a set of these brakes, would you?
Old 01-15-2007, 11:27 AM
sharky47
Set to Full-Auto
sharky47's Avatar
Hey, if you get all the parts together you are welcome to come do the swap in my shop.......might even have my blasting cabinet installed by then......
Old 01-15-2007, 11:31 AM
jerhofer
jerhofer's Avatar
I will keep that in mind.
Old 01-15-2007, 11:53 AM
tifosiman
tifosiman's Avatar
Nope.
For the rear, any year of rear 951/S2/968 calipers will bolt right up. You will want 86 951 rotors though, specifically for the offset issue you raise above. These are a straight bolt-on to your car as well.
When you source the rear 951/S2/968 calipers, just be certain to get the two bolts and two washers/spacers that go with each caliper. If you can't, the PET lists the part#'s and you could order them. I don't have the PET on this laptop or I would offer up part #'s for you.
Old 01-15-2007, 12:16 PM
Techno Duck
The bolt part #'s are N.040.108.1 M12x1.5x40
You need two spacers for each caliper, part #'s are 999.025.131.02 . Last time i checked these were $5 each. Tifo informed me that any 1/2 washer will work in place of this. Total cost is less than a dollar as opposed to $20 (thanks Tifo!).
I do not have a spare set of calipers to sell. Check on eBay...there are always a few sets for sale.
Old 01-15-2007, 12:49 PM
tifosiman
tifosiman's Avatar
Thanks Jon. Did I send you my spare washers? Those worked fine for you, right? I meant to measure them and take pics so that I could insert that into one of these threads for future search needs.
Old 01-15-2007, 12:52 PM
Techno Duck
Tifo, you did send me 4x of them and they worked great. They are a pretty generic size as i pulled 4 out of a hardware case to put the rear calipers on my friends car.
Old 01-15-2007, 01:06 PM
Pauerman
Pauerman's Avatar
I've got a front and rear set of 951 calipers with rotors, pads and hardware available - asking $250 for all or $135 for each set. Shipping not included.
Old 01-15-2007, 04:20 PM
jerhofer
jerhofer's Avatar
Default Calipers
I will take the rear brakes if you still have them. You can call me at: 512-964-8031
I can paypal you the money or send a money order. Whatever works.
Jerry
Quick Reply: Rear Brake Upgrade for 1985.5
