FS: '86 944S 36K miles (Not Turbo) (photos now)
#61
Originally Posted by Catfood
I dont see the 16 ventiler badging on the bumper pads.
#62
#63
I don't think it is an 86, it has late offset phonies on it.
Are we certain it isn't an S, and they just have the model year wrong?
#65
Originally Posted by Tom R.
I thought the 16 ventilier on the side moulding was only on the S2. I think the S and NA are visually identical.
#66
Every 944S I have seen has had the 16V molding. I'm certainly no expert, however.
DISCLAIMER: YMMV. Do not take with Alchohol. Do not operate heavy machinery. May cause rashes or bloating. Discontinue usage if headaches last longer than 114 hours.
#67
perhaps a few S owners or past owners will chime in. I do know that it is on the S2.
my earlier statement was incorrect. It should have started with other than the S under the rear spoiler the ....
#68
My 1987 S had them FWIW
#70
Lazer Beam Shooter
#71
Done With Sidepatch
Originally Posted by Andre Hedrick
No dents, that is the reflection of the his nieghbor's bush in the front yard about 35 feet away from the car.
If you guys think I would present a beater outside of my native forum, you have to be nuts!
#72
Rest in Peace
i cant tell early from late offsets. for a minute i thought they were late. add $1000 to my guesstimate if it is an 87S
I am will see if the owner has the original window sticker and options list.
Cheers,
#73
That can't be an 86, it's clear that the wheels are not early offset. It's probably an 87 944S, in very condition.
Eitherway, a photo of the engine would be much more conclusive. You can add and remove badging easily, but no one is going to swap a 944S engine for a typical 944 engine.
#74
Not saying it happened with this car, but you'd be amazed at the difficulty of finding (and price of, when you do) a good, used head for an S. There are actually quite a few floating around out there with NA mills after any number of things happened and the owner was confronted with spending the same amount on a replacement head as an entire 8v engine.
Micah
Micah
#75
This car has Ventiler mouldings, most S's I have seen have them unless they were removed, also has 7x15 wheels all around which was standard on the S model. The S was introduced in August 86 but I seem to remember reading that some models were sold before the model year change as 86 models. Can't back that up with a reference though. They may have bought it in late 86.
I say it is a legit S from those photos and description of owners who don't sound like they would add the S badging. VIN and engine photo would confirm.
Sure wish my paint looked like that
