Low oil pressure indication
Car (non-Porsche) gets low oil pressure indication after it warms up, but only with low rpm when coasting to a stop. It has new pressure sender, new 20W-50 oil, and new OEM filter.
Inspection of the oil pan and head show no signs of oil starvation or sludge. The new oil pressure sender acts the same as the old one, i.e., the low oil pressure symptoms are the same as before installing the new sender.
So, why would a low oil pressure indication happen after warmup, but not before?
Official Rennlist
Borat Impersonator
Borat Impersonator
Sounds like rod bearings are worn, or maybe wrong oil.
As the engine warms up, the oil gets thinner, which is why oil pressure is high when the engine is cold and idling then drops when the engine is warm and idling.
