Anyone have an S2 in the Hampton Roads area? I would like to compare.....
Their is a local dyno day on the 20th of this month. I would like to compare a stock S2 to my modified 944S before I swap the AFM out with a MAF. Kind of a same dyno, same day, etc. test. I would gladly pay for your dyno time
Canadian Yankee
I dynoed at 180.5rwhp and 185.7wtq. So that may give you an idea, I wish I was closer to help you out. I would really like to see what you put down.
Good Luck
Brandon J
Good Luck
Brandon J
Good Luck
Brandon J
Good Luck
Brandon J
not really. Dyno type, outside temp, humidity, elevation, etc. I use a Dyno Dynamics Dyno. Dynojets read differently.
