Failed Inspection - Now what?
Old 12-21-2006 | 12:24 AM
white924s's Avatar
white924s
well you may have issues with the car that need sorting out, but if you're looking for a quick fix, a lot of shops (not going to name names here, but ask around) will do a "stevie wonder" inspection, particularly if you grease the proverbial wheels, so you could do that and then fix whatever issues your car has at your leisure
Old 12-21-2006 | 01:14 AM
jeeper31's Avatar
jeeper31
Car seems to be running well. As far as gas mileage, I haven't checked since I got it home but on the trip from Ohio to New York I think I got about 27 mpg. My first 944 failed and all i did was put in NGK plugs and it passed.
I didn't get the car real hot before I brough it in however, after it failed the mechanic said he ran it at about 60mph for a few minutes before he did the test again.
Dan - What is e-check? Never heard of it.
Old 12-21-2006 | 02:12 AM
Keithr726's Avatar
Keithr726
+1 for O2 sensor, my old car didn't passed because it was bad.
Old 12-21-2006 | 03:28 AM
luckett's Avatar
luckett
From: San Francisco, CA Porsche: '92 968 Blk/Cashmere
check your distributor cap and rotor for wear.
Old 12-21-2006 | 08:57 AM
jeeper31's Avatar
jeeper31
Ok. If starting with spark plugs and O2 sensor what should I buy? I used to use NGK on my other 2 944s. Actually I remember my 83 didn't pass and I changed plugs and it did. Don't remember the test values though. How about O2 sensor?Replaced in my 944S and if I remember correctly there was a Bosch replacement for a lot less $.
Old 12-21-2006 | 10:04 AM
GeneralTso's Avatar
GeneralTso
Did the shop you took it to let your car sit for a long time before running emissions? If so, find another emissions station that will do it while you wait so you don't have to drop the car off and have it cool down for 4 hours before they put it on the sniffer...
Old 12-21-2006 | 10:55 AM
jeeper31's Avatar
jeeper31
I drove the car to the station from work. I tprobably sat about 20 minutes before they pulled it in for the safety check and then another 20 before the dyno. After it failed the first time he ran ti at 60 mph for a few minutes and then did it again however, after the first few minutes of the test the computer plug fell out of the outlet and they had to reboot the system and start all over.
Old 12-21-2006 | 01:47 PM
Energy9's Avatar
Energy9
Smile
Car inspections are like everything else. The more you pay the better your chances od passing.
Old 12-21-2006 | 01:49 PM
ibkevin's Avatar
ibkevin
Defending the Border
Rest In Peace
With a late O2 sensor, test it to make sure the output voltage is rising and falling. Unfortunately, the lates are expensive.
Run the tank down to an 1/8th, add methanol, and leave the car running when you get to the inspection station.
Done deal.
Old 12-21-2006 | 02:16 PM
jeeper31's Avatar
jeeper31
Done deal.
is this a surefire way to pass?
Where do I get methanol and how much do i add?
Old 12-21-2006 | 02:43 PM
ibkevin's Avatar
ibkevin
Rest In Peace
Test you're O2 sensor first as per Clark's, I've been down this path with both my cars.
Local building center should have meth in the paint section. I've also used Kragen's "Guaranteed To Pass" (G2P) and had better numbers than the test two years earlier.
Be sure to get the car hot and keep her running while waiting for your test, I did mine at a place that I knew would be dead right after lunch.
Old 12-21-2006 | 05:19 PM
arbeitm's Avatar
arbeitm
I'm going to ask a stupid question here.
Judging from the pictures of your car, the exhaust doesn't look stock (if I remember correctly). Are you sure you have a CAT and not a test pipe under there? Did you or anyone take a look?
Old 12-21-2006 | 10:06 PM
jeeper31's Avatar
jeeper31
I did not take a look but the PO said it does have a CAT. I think the exhaust is stock but he changed the tip as the old one got corroded.
Spoke to the PO's mechanic. He said what I should do is take the vacuum hose off the FPR. He said when the turbo kicks in more fuel is used. By dosconnecting the vac hose it stops the extra fuel and will bring the levels down.
I looked at the PO's records. The spark plugs haven't been changed in about 10,000 miles and I do not see any record of the O2 sensor being changed. If I replaced the sensor and the plugs what are my chances that it would fix my problem?
Old 12-21-2006 | 10:34 PM
mhm993's Avatar
mhm993
Dan--congrats on the purchase. Ummm, did you consider peeling the sticker off the OLD car before you sold it??!!
Old 12-21-2006 | 10:42 PM
jeeper31's Avatar
jeeper31
Hey Mark - How you doing?
Didn't even think of taking the old sticker off. Although it was hard enough to get the wife to agree to a Turbo S. She bought the "Everone said I should get a Turbo" line but she knows they didn't say "S"!!!!!
That would have been a good idea.
Quick Reply: Failed Inspection - Now what?
