something wrong.....gas shuts off at 5K
Lazer Beam Shooter
Originally Posted by jgleano
I'm currently running 87 octane but usually run 91.
Does it do this when you run 91 octane or are you not sure?
Lazer Beam Shooter
Oh fo sho fo sho.
You can tell if your car is a CA car too by pulling back the rear hatch carpet on the drivers side and looking at the option codes sticker for the number
M027 (version for california)
Discription is pretty slight so.
Fuel Pump/Injectors/FPR/Sparkplugs/Wires/Coil/Cap/Rotor/Ref Sensors/Clogged Cat
-Fishey
P.S. Could be a broken valve-spring or burnt valves as well.
-Fishey
