Getting rid of mold/mildew
Next time someone asks $100 or $200 to get rid of mold/mildew in your car don't scoff.
Here is a bit of what i did to my NA. The water leak was isolated to the passenger side, and water pooled under the rear seat, and on the rear passenger floor.
Pretty simple, right?
I took out the passenger seat and used my bissel carpet steamer on the floor and wheel well. Didn't do it all
I took the seatbelts out and removed the rear seat bottom after i took off the eight clips in the hatch area. the bottom of the seat stank. I put the seat in the garage on the hatch of the 951 and the whole garage stank.
I mixed a little oxy clean with water in an empty febreeze bottle. i used the whole bottle in the car last week, along with a can of lysol. the big size can! sprayed the oxy clean all over and under on friday or saturday night.
I took the other seatbelt bolt out and pulled the carpet up, pulled the carpet down etc. I then took my wife's sharper image ionizing 1875 watt blow dryer and set it on medium, wedged it in and let it blow. i went in and heated up a slice of yesterday's pizza (you gotta be from NY to understand that one).
then i moved the dryer to another area. i Didn't just want the carpet or padding to dry, i wanted to fry the mold spores.
after a few hours of that with the blow dryer i sprayed a little lysol on the inside areas, shot the dryer over the areas, and put the carpet back where it was.
I took some clorox spray and sprayed the underside of the rear seat. the material was peeled back a bit and it stunk real bad under there. the moment i shot that area the blue material that backs the vinyl changed colors. i grabbed the hose and hosed it down. sprayed the foam with water, then clorox, then squoze, then sprayed water etc. the seat bottom is now in my basement next to my boiler with something wedging the material from the foam, drying out.
when my wife gets home in a little while she will open the door of the 944 and tell me if i cured the problem. if not, the car definitely has to be sold.
Originally Posted by TheCooler
Buy recaros ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
In my experience the mold/mildew will never be gone. I think the spores lay dormant until it is humid enough and here we go again. A friend of mine just sold a boxter for the same reason (perforated leather..even worse). Problem is much more pronounced here in the south. You have to be careful leaving your car in the garage with the windows up for extended periods of time. Ask me how I know..thank god it wasn't the 951.
